VCDS codes secondhand warranty ?
Just got an 09 plate pre refresh Elegance from D M Keiths, Leeds branch and I have a couple of issues.( one of them is it looks like some one walked up my bonnet in-between me having the test drive and getting it home, and I didn't notice it till I got home and was showing the car to my eldest lad...) the other is I got a friend to scan it with VCDS and to my surprise it came up with two errors.
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 TB HW: 03G 906 021 AN
Component: R4 1,9l EDC G000SG 2047
Revision: --H08--- Serial number: SKX7Z0H63230A8
Coding: 0000071
Shop #: WSC 73430 790 00000
VCID: 72E06E236DB4003
1 Fault Found:
005712 - Powertrain Data Bus
P1650 - 000 - Missing Message from Instrument Cluster
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 10
Mileage: 54851 km
Time Indication: 0
Date: 2000.00.00
Time: 13:31:21
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.36 V
Bin. Bits: 00101100
Bin. Bits: 00000000
Bin. Bits: 00100001
Readiness: 0 0 0 0 0
and
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 99801A085283007F3F04850540085F96907CA0
Shop #: WSC 22013 576 90947
VCID: 830EBBE7C20EB9B
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 22013
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 3
Mileage: 44593 km
Time Indication: 0
Date: 2000.00.00
Time: 09:24:13
Should the faults be covered under warranty ?
The Alarm ultrasonics DTC doesn't worry me (if needs be i can do it myself, found it mentioned elsewhere in the forum) but the 005712 - Powertrain Data Bus does... We reset the DTC on the engine and it came back straight away. The codes log is from after i reset it, before I reset the DTC I noticed that the mileage matched the last time it was serviced as though they had simply cleared the DTC log on an ongoing problem. (if it as a problem..)
any help appreciated on how serious it is, or if it might jump out and bite me if it's not sorted ....
