octavia mk2 front wishbone rear bush
hello im going to need some wishbone rear bushes soon. just wondered which make to buy as ive heard some are modified type? many thanks.
thanks for that will have a look.
Powerflex or superpro poly bushes http://www.upratedbushshop.com/ :happy:
Which sets did you end up ordering for yours Alan?
I need to email Alias ,he got me them direct
Cheers. Just want to price it up as it's on my spring 'to do' list :)
Or I might go to him and get everything done in one hit, as I need alignment checking :thumbup:
When...? :p :D Let me know when you want to pop in for initial check.
The walls have ears ;)
Will give you a shout. Pretty certain it needs adjustment, plus Manchester to Leeds just for an 'initial check' is a bit of a trip :D
Superpro are much better engineered IMO
Just better than OEM or better than Powerflex?
I fitted the OE bushes from off an S3 / TT mk2. They are a solid bush design and very firm but with no extra vibration through the steering wheel.
The thing is he checks out everything with a stethescope to see which are worn , you may not nee a full sett, either that or go for 1st thing and then he can replace the worn bushes
Better than power flex - far superior material and steel inserts
Just a thought - do you already have anti lift? Because superpro do an off centre bush which does the same
OK, good to know. No, don't have anti-lift. Bushes are all standard and could well be original! Just the springs and dampers I've swapped.
Got a link to the Superpro anti-lift offering?
Here you go fella
SPF3273K List Price £83.97 plus VAT
Front Control Arm, Rear Bush Kit With Anti Lift
As per the SPF3271K this improved design bush will out last OEM bushes significantly however, these bushes have been designed with an offset mounting. This allows for a greater caster angle to be achieved cutting down on wheel hop and spin.
Comes with SuperPro's unrivalled 3 Year, 36,000 Mile Warranty.
This bush kit is also available in car sets KIT5229ADJK.
http://www.superpro.eu.com/catalogue/19/skoda-octavia-mkii-2004-_to-current/#SPF3273K
Great stuff - thanks for the info :thumbup:
