Scout alloys
I was enquiring at my garage about replacing my steel spare wheel for a fullsize alloy. The quote for wheel and tyre was over £400! Does this sound realistic? Any opinions greatfully receied.
You will find the alloy WILL stick up into the boot as its wider than the steel spare and its a tight fit as I tried it once
I bought a spare alloy when I ordered my scout cost was ~£170 for the wheel (and £125 for a tyre from mytyres)
The Alloy does stick up a little which raises the boot floor a touch.
Mark
eBay would be my approach.
Proteus alloys are as rare as rocking horse muck so you've no chance of finding a used one.
It'll have to be brand new from a delaer unless you are very lucky...
Its the same with Pegasus alloys too :thumbdown:
What happens to the ones that are changed under warrenty as there must be plenty of them around ?
I'd just stick with the normal steel spare. After all it's only there for emergencies.
Seems a bit of a waste of money, IMO of course.
They are refurbed and used for the next warranty claim.
+1, I've never understood the desire for a fifth alloy as a spare, the steel spare is only a short term solution until the original tyre can be repaired / replaced and then hidden in the boot for another few years.
Thanks for your thoughts, but the reason for asking is that Skoda UK advised me not to tow a caravan using the steel spare!( Ishould have stated this at the beginning. Sorry.)
I can see absolutely no reason for that advice whatsoever - the spare steel wheel, properly inflated, will be just as capable for towing as the 'proper' alloy.
Yes I agree, I tow a caravan and the first thing I asked for was a spare wheel and NOT a can of gunk, if the steel spare is a 'normal tyre' why does it have a 50mph speed sticker on it ?
The steel spare supplied with a Scout is 16 inch - so different size to the normal alloys - which might be the reason for the Skoda UK advice.
Although the wheel is a full size steel wheel with a normal tyre on it is a different size to the normal wheels. For the Scout the normal tyre is 225/50/R17 whereas the spare is a 205/55/R16 which gives a different rolling radius and could cause issues.
If you had 16 inch alloys then putting on a 16 inch spare steel wheel would be fine.
