Problems, Problems, Problems
As per another thread had a water leak and on inspecting that this morning I found brake fluid under the car in the garage near where the front right wheel had been sat. Had a good look but couldnt see any leak from the pipework or caliper (checked both sides) I then noticed about halfway along the car that there was brake fluid splashed around the brake lines that run to the rear of the car, it was right by where there is a sort of cross member with the pair of pipes running under it, cleaned it up but couldnt see a split or anything, the pipes look in very good condition so I am wondering if its common for the pipes to split in this area of the car before I start dismantleing.
I also have noticed a sort of rattle when I accelerate, it sounds like a bearing but cant be sure. It only happens when I accelerate and if I release the accelerator and coast it stops then starts again as soon as you give it gas. Is this normal for a vRS or have I gott problems.
