Advice of fitting an Induction kit
NEED SOME ADVICE ASAP
:confused: Want to fit my induction kit to My VRS OCTY tomorrow but after fitting it it will mean one pipe will sit their doing nothing it is the black pipe on the left hand side of the box on a 'Pinch collar' style releaseing mechanism,.
What do I do with it after put my i kit on. :confused:
Place some mesh in it,
Place a small cut to fit piece of foam,
Remove the pipe.
I have seen one install with like a mini filter should I fit one of these help please. email me back or 0797 7389561 and i'll call you back Thanks a million people. :thumbup:
The CAIs i've fitted always came with the mini K&N type filters to fit to these small pipes.
the little pipe is for the secondary air pump the feeds air into the exhaust manifold(i think) to reduce emmissions when started. it should have a filter of some sort on it really. according to jabba ofcourse :o
btw jabba sell small filters with the correct fitting to connect onto this pipe so there is no cutting or adjustements needed :)
:iagree:
thanks i'll phone jabba up
doesn't it come with a hole to connect it too?mine did(green hurricane)
mine didnt :(
