Warning Light - ABS problem?
Hi all,
Please take a look at the VCDS trace below - does this look like bad news? Seems to be an ABS sensor problem, I'm guessing the AWD problem might be a red-herring? I'm getting the "skidding" warning light on the dash:
Friday,30,March,2012,14:10:36:28456
VCDS Version: Release 11.11.2
Data version: 20120126
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72 76
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 021 MD HW: 03G 906 021 AB
Component: R4 2,0L EDC G000SG 9095
Revision: --H06--- Serial number: SKZ7Z0F3996131
Coding: 0000172
Shop #: WSC 25086 576 68700
VCID: 6DD596FB748ADFB
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0023170
Shop #: WSC 73430 790 00000
VCID: 72EF85876DB4003
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
012 - Electrical Fault in Circuit
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 H
Component: ClimatronicPQ35 084 0305
Shop #: WSC 00000 000 00000
VCID: 3B7168A37A7E81B
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004666012
Coding: 418A0F030004140000110D000000000000087F075C0000
VCID: 6CD39BFF4F90D63
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 191206 022 0601
Coding: 00055223
Shop #: WSC 73430
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 201106 020 0105
Coding: 00471077
Shop #: WSC 73430
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0YC30C
Coding: 0020788
VCID: 3D7566BB646A8FB
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000042
Shop #: WSC 25086 576 94681
VCID: 74E3839F17A00E3
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 912 D HW: 1Z0 920 912 D
Component: KOMBIINSTRUMENT VD1 1610
Revision: V1610056 Serial number: SKZ7Z0F3996131
Coding: 0007401
VCID: 36677997415C5C3
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0020
Revision: H04 02 Serial number: 15110602000666
Coding: BD3F074007002303
VCID: 2F694CF3BE066DB
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1610
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 005 0954
Coding: 0000756
VCID: 387B77AF4B48AA3
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
Shop #: WSC 02069 000 90108
VCID: 35657E9B5C5A57B
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 98801A085283007F3F04850540085F96907CA0
VCID: 83015043C20EB9B
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 73430
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 2
Reset counter: 240
Mileage: 78126 km
Time Indication: 0
Date: 2000.00.00
Time: 11:34:41
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000756
VCID: 397D72AB7042B3B
1 Fault Found:
00121 - Outside Warning Light/Door exit Light Passenger Side
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C
Component: Radio FO3 019 0034
Revision: 00019000 Serial number: SKZ7Z3G0125440
Coding: 0000402
VCID: 2E5751F7B90C643
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 005 0907
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 377974934656A5B
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
Address 76: Park Assist Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 B HW: 1Z0 919 283 B
Component: Parkhilfe 4-Kan H04 0020
Coding: 0000001
End ---------------------------------------------------------------------
Oh dear, the address 03 tells us all we need to know, you have the dreaded G201 pressure sensor failure. Luckily there is now a rebuild kit available, makes a change from the £1000+ people have been quoted for ABS pump replacement. Do a search on here and you should find a thread about it somewhere, in the Octavia section I think.
Ian
Thanks for the replies, I'll get doing some research then... just to give me a heads up before I visit my dealer, what is the likely damage to put this right? In the meantime, what probably isn't working properly anymore?!
Your abs and esp probably won't be working.
Iirc the original fix was a replacement at well over a grand but I believe a repair kit is now available which brings the cost down to around £400 or £500.
Well, fair play to Skoda, they have offered me a good deal - because I've supplied them with the diagnostic report, they will waive the £78 diagnostic charge *if* the fault I've reported is still present in memory when they get the car. Also, due to the car's age (less than 60 months) they have offered to pay 100% parts and 50% labour - I really couldn't have asked for fairer than that :)
Edited by riph72
You have a good deal I paid 645(out of 1500 ) 6 months out of warranty, but that was 3 years ago, before the kit, and before I was on here!
under SOGA you have 6 years against supplying dealer so push for a FOC repair.
All depends if the OP is willing to take it to court or not. Skoda will not admit that there is an inherrent fault - the only way you can claim at 4-6 years.
The OP can take it to court and use the evidence of others having the same issue - if he's lucky he'll be able to set a presedence, if not then he'll get nothing.
Nobody's taken it to court yet.
They aren't the supplying dealer - I'm in Swansea, I bought the car in Southampton and the last I heard, they went out of business!
I could push for FOC and/or go the court route, but given the fact that they could have just told me to sod off altogether, I think I'll quit while I'm relatively ahead.
Not sure what 50% labour will be, but it's going to cost a lot less than 100% :)
If the warning light comes on approx 10 mins after you start the engine then it is the Load Signal Cable from the alternator that is broken.
(I should add, from my own experience: based upon a similar story of a Seat)
Edited by Rab-k
FYI - I have had my money refunded by VW for a previous repair.
Some on the Facebook page for the MK60 issue have had it refunded even after getting the repair done at an independent.
Seems VW finally seeing the light.
Even when I got mine done VW and Audi were paying in full up to 5 years, just Skoda and Seat left out in the cold, that is why Seat came up with their fix kit :happy:
