gauges
for everyone tapping into this and that for power, why dont you all just wire it from under the steering wheel. Theres a row of 5 nuts in a block that splits the cars power to CCU and relays ect. This is the most solid stable power sorce in the car (other than the battery its self)
ANY addition to the cars electrics even as small as gauges should really be wired and fused from here. see here...
the nut under 447 relay is the ignition power so any thing wired to this will come on with your ignintion. (this is labled with a yellow sticker too) Simply fuse from this and earth the gauges accordingly. TBH, i find this easier than fannying about with OEM loom wires trying to find whats what.
you can just see it, but what is the 15amp fuse in the green holder above the black fuses?
  • Replies 89
  • Views 10.4k
  • for everyone tapping into this and that for power, why dont you all just wire it from under the steering wheel. Theres a row of 5 nuts in a block that splits the cars power to CCU and relays ect.
  • I got one of these, didn't fit straight away had to file some of it to make it fit.
  • here you go. PS not my car anymore!
Maybe its self destruct :D
reckon it is mate..... arrrgh! this f'ing Airbag light!
Oooo my first piece of the puzzle
But um????? Which is the top ??
And what bit was it that needed to come off ??
Does it actually ,matter? lol. i guess u could tell when u pop out the cubby hole.
Very true........ You woulda thunk anywho :D
Very nice :) I would do that but I have the double din sat nav thingy lol
I did almost get a double din, i got the flip up tho, so another reason they have to go underneath lol
I just need gauges now lol
I'm sure I put mine in this way up;
The bits I had to file down are the square bits on the top side but I would try it as is first before getting carried away with the file.
Yeah mate i will try 1st, i was just planning ahead to avoid panic lol
  • 5 months later...
I just dug this up :)
Theres a part where Gee says about the under steering wheel conections.... Itls one ign and another permi power ?
Lloyd if you really stuck i am not far away and happy to show you where to wire from
Cheers guys :)
Nice to know theres some saviours at hand :)
I have mr dave offering some help too.... But refuses to let me curl up
And cry in a corner :D
Scary stuff...... :)
I did spy the fuses when putting phone mic up lol
:D i'll keep a cam ready incase i have it in flames lol
