New front and rear disc ordered
Discs on way off eBay thanks guys for help
Skoda Fabia VRS 2003-2007
Front & Rear Axle Set
Performance Dimpled & Grooved Brake Disc Set and Mintex Brake Pads
Included in the Brake Kit;
2 Front Brake Discs 288mm 5 Stud Vented
2 Rear Brake Discs 232mm 5 Stud Solid
Front and Rear Mintex Brake Pads
**All Brake Disc Images are for Pattern Illustration Only unless otherwise stated**
Our Fabia Brake Discs are manufactured from premium quality blanks that have undergone high quality checks, when manufactured they are produced from 100% Steel batch process, Hardness and Tensile Strength is inspected and they are also dyno balanced, through the process run-out is also controlled to ensure a high quality brake disc is produced, finally surface venting and cooling patterns are then CNC machined using the latest in technology, also to a surface tolerance of just .001 mm which is 1 micron. When fitting brake discs please be sure to read our short fitting guide if you have any questions please contact us 0845 519 3568.
Edited by darren200874
