2005 Elegance
Hi
I have a 2005 Elegance 2.0 TD is there an auxiliary input for MP3 players if so where???
Not on a 2005 there won't be unless it's been aftermarket added.
:( that answers that then
Sorry :( I have an 06 and know how it feels. Though I think you can add it if you've changed the head unit...............
Hi
Not possible, as said. You'd need to upgrade the headunit, then retrofit one.
Alternatively, you could look for something like a Connects2 unit, which would provide a 3.5mm jack input, or an iPod connection to the original Stream you have.
You probally have the Stream mp3 Head Unit and the connection you need is in the back. I've researched this as I want to do this myself. I have the HU unit wiring diagram and the connectors required for retro fitting also a step by step guide for this. It's a very easy fitment if you are good at DIY?
A 2005 Elegance won't have the Stream MP3, which is the lowest model you can retrofit an AUX socket to.
Don't believe the MP3 model was fitted until MY07, so it would be late 06-plates and 56-plates as the earliest.
