Top mounts popping out?
Anyone that had any experience with that?I just installed weitec gt-dampers with their lowering-springs and both mounts are sitting 2 cm above where it should be!
The front-suspensions knocks at every bump, pretty sure it shouldn't be that way :
Skickat från min HTC One X via Tapatalk 2
Hi,
Check out this one, there might be that you mounted the springs and dampers wrong.
http://www.fabia-vrs...suspension-fit/
Den vil kanskje hjelpe deg en god del :)
Edited by joten
Followed every step I'm afraid, had vw-instructions.
Thanks anyways!
If it's any help, the Top-mounts are sitting correctly when the wheels are up in the air...
Edit: apart from the 4wheel-alignment.
Want to do that when everythings sorted!!!
Edited by Confide
