HELP! Weird bleeping noise
Hey all im having an issue where everytime i give slight acceleration i get a constant bleeping sound and the handbrake light keeps flashing... The bleep is different to the one you get when you drive with your handbrake up... My brakes are quite spongy and take quite some pressure to stop but all discs and pads are in good condition... Oh and my passenger side rear caliper was once leaking from the nipple but got that replaced but i checked yday on that tyre and it was wet and also on the hose of the caliper but not the nipple
could be a damaged hose or seal but the beeping will more than likely be low brake fluid.
Thanks mattie... I tried checking the brake fluid level today and as awkward as it is to get to the tank i just unscrewed the cap and the fluid was visible mid way down?
i think it should be somewhere near the top to be honest mate. Id also get the wheel off and get someone to pump the brakes so you can locate the leak and sort it
