Few problems on 53 plate VRS
Noticed I had 2 wet rear carpets today, I think I need to replace the seals.... But is it the window seal or the whole door seal
Also drivers side rear disc over heated, I think may have a sticky caliper but never happened before!!
Any advise will be great :)
Look at the 'Leaky door seals' topic and that will explain everything :)
As for the rear caliper sticking, look for a topic that has the words 'Sharan springs in' basically caliper springs off a VW Sharan that allow the handbrake cable to release fully
Took door cards off today and brought some sealant, applied as should etc and then about 30 mins ago started raining :( no water leaking through yet but I'm worries that with the water in door, will keep the silicone sloshy lol. Should I just leave it to harden and see how it pans out?? Or remove and start again
