Vrs updated clutch
I've had a little look around and keep saying names thrown all over the place.
I'm now running stage 2 can anyone recommend a good clutch to replace my oem one with that isn't gunna kill me on money but needs to be able to withstand th torgue. Also is it worth changing the fly wheel etc? Links to products would be great
Thanks, Toby.
Bumpp
Helix SMF? Not heard anything bad about them, save a decent amount of weight over the dmf too iirc
I have Sachs Peformance Clutch and kept OEM flywheel - Clutch is heavier that standard but you get used to that (rated to 400lb ft) - heard that SMF can be noisy and not so good for use in a lot of slow traffic so I chose a middle option.
I have the above and now have 340lb/ft
torque! Well worth the money
Any links to best place to buy the Sachs from? Thanks
bump for this. also needing a clutch
Try cg motorsport in leeds ive had a quote for £580 full job lot smf convertion and ive not heard any bad reviews abou them at al
