New Car - Wind Noise
Hi Steb.
Car went to dealer for replacement parcel shelf a few weeks ago. I asked them to look at the wind noise at the same time and was informed that it couldn't be replicated - however, it has now disappeared completely so assuming it was fixed.
Skoda dealer here is great and very helpful; swapped rear fogs over for free as I bought a litre of oil.
  • Replies 57
  • Views 15.1k
  • The simple soloution here is not to break the national speed limit! Problem solved instantly! My diagnostic invoice is in the post
  • I will take delivery of my vrs in November and it looks like a 75 - 80 mph test drive first on the bypass before I do anything else, to see if mine is going to suffer the same issue. You would think s
  • Here is a picture of the area of the "fix". Its not the easiest of places to photograph unfortunately. If you open the bonnet and look at the top rear-side of the chrome grill, where it meets the meta
Black_Sheep,
what is your LocStat and were is your local Skoda dealership?
I am near JHQ and our local is in Karst.
will look at the lights once the weather gets better.
Steb
Steb - PM sent. Not much snow here yet - just freezing cold.
I have similar issue with my car and at first I was told this wa due to the design. After a couple of months hoping it would sort itsel out the car was taken in and llater I was told that they could not find the cource of the problem but suggested it may have to do with the design of the mirror. I feel that Skoda is eitherunable or reluctant to contac the manufacturer regarding problems with their cars and as a result just fob people off. Is Skoda really part of the VW-Audi group? it sure does not show it. Skoda may use german technology in building their cars but unfortunately not to german standards. Am i expecting too much, as somebody told me the other, from a skoda?
noticed this today, while overtaking
Problem solved took the grill off and put some foam around the edge as in other threads and bobs your uncle.
went upto 140 and no whistle easy.
however have noticed hat in my old VRS if went over 100 the lights auto came on, now in the Blackline they dont. havent looked on any threads just thought i would throw it out there.
Have a Merry Chriatmas all.
there is a known fault with the putty on the windows (at least on my 2.0tdi elegance 140). i had a similar problem trying to find where the noise was coming from and thought it was the door seal. skoda are aware of this issue is what the guy at the dealership said.
  • 4 weeks later...
Here is a picture of the area of the "fix". Its not the easiest of places to photograph unfortunately. If you open the bonnet and look at the top rear-side of the chrome grill, where it meets the metal of the bonnet then the fix is to stick a strip of foam to fill this gap. Presumably the dealer had to remove the grill to stick this to the rear side of the grill and then re-attach it. The noise was apparently due to airflow being disturbed in the area of this gap between the grill and the bonnet. I've since done 1500 miles and the whistling has not returned, would advise you to just take it to the dealer and let them fix it under warranty, the fix is on their computer system.
Cheers mj - printed this and gave it to the dealer,together with the TPI# (twice) and its now fixed. Had the car on the motorway today and no wind noise at all even up at 80 erm 60...
