Tow Bar
This thread won't be for everyone here. However, old fools like me who use a trailer for moving things might find it of interest.
My car has the 1.6 diesel engine so there is plenty of torque to keep the whole caravan rolling with a loaded trailer up to 1.2 tonnes. I have a field I am developing as a large allotment for fruit and veg so moving a pile of manure or dirt around isn't unusual.
Now the hard part.
The tow bar kit costs £197 which includes a detachable arm with the ball hitch on the end, a plastic cover for the greasy ball and the tubular bracket with two plate steel arms which attach to the chassis rails.
I wanted to give the tow bar a good coat of paint as they often come with only a thin coat of black paint and quickly rust. However, this one comes with a pretty good coating of something like smooth Hammerite. I decided I would still give it a couple of additional coats so it is now bright red.
I then had to remove the plastic 'bumper'. Having undone the various screws and clips, I applied all the force I thought it would take and failed to get it to detach from the upper sides behind the rear wheels.
The fitting instructions also included directions to cut out and fit a plastic cover in the bumper. This has to be removed to allow the tow bar to be used (when the detachable hitch is fitted). As a result I decided to take all the pieces back to my local friendly(?!!) Skoda dealership and get them to do the job.
I had also purchased the electrical kit to be fitted by the garage. This requires the Cambus (or whatever it is called) to be tweaked to let the car know it is going to have the trailer electricals to drive from time to time. This kit costs just over £70.
The garage has just invited me to bring the car to them tomorrow when they plan to take 5 hours to remove the bumper, fit the tow bar and electricals and install the cover plate, then re-assemble. As they charge about £70/hour, I will have to then pay around £350 for this privilege.
So a Skoda installed tow bar is going to cost me £197+£75+£350 = £620 (roughly - final bill not seen yet)
It better be the best bl**dy tow bar ever!
By the way, as I live 25 miles from the garage and installation will take most of the day, I face the prospect of a day spent wandering round a Norfolk town trying to keep warm, dry and fed. No courtesy car can be provided!
Sorry if my comments appear a bit fraught. I will report back when the job is done.
I wonder how much the genuine Skoda one is, fitted? It'll be a fixed price, for sure. Factory one is £320, so sadly a dealer one is probably more..
I had one fitted on our new Fabia Elegance 1.6 CR. Dealer DM Keith, Bradford, advised against the factory one, arranged for a detachable bar to be fitted locally and charged £335 fitted (September 2010) which I thought was very reasonable. It's an excellent towbar too!
OK, so the towbar is fitted.
The final cost is £197+£71+£300=£568
The price for installation was negotiated. The mechanic had a lot to do. I left the car at the garage at 8:15 for an 8:30 start and collected it at 16:00.
I have to wait for the glue on the frame for the cover panel to set before fitting it. It also needs to be painted. So I have to find a can of paint.
The job required the removal of the crash bar from under the plastic bumper. So I have that as well.
The electrical work required a fair bit of the internal trim to be removed. I assumed that the connections would just be scotchblocked to the wires going into the lamps but they were connected further inside the car. I am not sure why.
I haven't tested any of it yet. My current trailer has a UK 7 pin plug so I have also got an adaptor to change the European 13 pin socket into a 7 pin one. I can test the main lights all work but not the link to the trailer battery.
I'll post more when I have tried the thing with a suitable trailer. My current trailer is too big for the Fabia. I intend to sell it and get something smaller.
Going back to the garage, I was dissapointed with their reluctance to provide a courtesy car. I have tried 2 Skoda dealers recently and neither would help me with local transport. The first was pretty disappointing generally so I won't go back to them if I can avoid it. Yesterday was a struggle. Both dealers are in large towns about 25 miles from my home so in each case I had to spend time wandering about looking at shop windows, plus the occasional cup of tea. After spending nearly £600 with yesterday's dealer I felt a car should be available. However...
So, more news when I have tried towing.
Plenty of independant tow bar specialists around. Usef a mobile fitter for our last Fabia, detachable tow bar with single electrics fitted £299. Came to the house and took around 3 hours.
Lee
I agree an independent fitter woudl probably have done the job for less. I considered buying a Witter bar for about £140 rather than the Skoda one for £197. What put me off the idea was:-
a. risk to the car warrantee (still about 15 months to go)
b. getting the car's computer reset to work the electrics for the trailer.
Moving on, I tried the trailer lights and got a shock. Everything on the trailer worked. But the rear fog light on the car had died.
Panic
I took the ofside rear light cluster off, checked the bulb and wiring.
No electricity to bulb back as far as the socket inside the rear quarter panel
More panic
Then I had a thought.
I unplugged the trailer and the car light worked!!
It's just too clever!
Other things
The adaptor for the 7 pin socket puts the plug on the trailer upside down. This means the slot in what is normally the bottom of the plug is now at the top and therefore more likely to collect water in the plug and socket in wet weather.
Also, it's easier to put the adaptor on the trailer plug before fitting the adaptor to the car socket.
The flap on the car socket fouls the clips to hold the new cover plate in the bumper. It's a small point and it can be forced over the clip, but it is disappointing.
To be fair to the garage, I did press them to reduce the fitting costs (=time) and they did take longer than planned. They gave me a bottle of screenwash and one of polish for the paintwork in compensation for the delay so I can't complain on that score.
More when I have tried the towbar with a trailer.
i had a detachable tow bar fitted 6 weeks ago,using a specific wiring kit the price was £385 all in,although they couldn't get the reversing sensors to switch off when engaging reverse.
I must call them and find out what they are going to do about it,i seem to remember they mentioned something about coding.
Skoda dealer quoted me £825 for tow bar so a massive difference.
Yep it needs coding, someone like Sharkperformance will do this for £10-£20.
Or try and find a briskoda member local who has VCDS.
Lee
It's a small point but there is no good place to attach a safety cable from the trailer. It would be obvious to put it round the detachable ball hitch just below the ball but if it comes loose...
I am considering fitting a loop bolted through the rear of the wheel well with a reinforcing plate on the inside.
Any other ideas?
When I had my towbar fitted, I asked them to fit a bumper protector. They advised me not to have the bumper protector as it makes the reverse sensors work all the time reverse is engaged. I don't know if you have one fitted but it may be helpful to know this.
Why oh why are you going to the Skoda dealer, most of them only farm it out to a specialist fitting company, you would have been much better going to one of them directly. They also have the knowledge and some of them the equipment to also do the coding the car needs to know when there is a trailer attached.
Ian
My cars reverse sensors are not affected with tow bar in place unless towing,I need to get mine coded to stop it going off when reversing trailer,luckily a friend has just started up a vag diagnostics company he reckons it will be easy to do :happy: .
My tow bar has a small hole in the mounting bracket where the tow bar attaches its not the easiest to attach but it does just.
I tried the tow bar yesterday. There are a couple of things worth mentioning.
The detachable ball hitch is a real pain to fit. The lever to release the mount has to be pressed while fitting it to the car. The spring is strong, you also have to press a button and put the thing in place. So strong fingers, hands and arms are needed while lying upside down to locate it. I don't recommend it to anyone with small or weak hands.
The car towed a large-ish trailer very well once rolling. However, pulling away presents more of a challenge as first gear on the 1.6 diesel is quite high. Even with the torque of the diesel engine, this requires more revs than normal and the clutch suffers. So don't plan a trip through London' traffic or similar if you want the clutch to last. It is OK on cross-country trips though.
The safety wire can be routed behind (or logically, in front) of the ball hitch and then clipped onto the tie-down ring on the offside boot floor (under the spare wheel) if the wire is long enough. Otherwise, with the Skoda tow bar you need another attachment point.
The trailer I hired for the towing test had 2 axles (similar to an Ifor Williams GD85). This makes the download on the hitch change as you raise the trailer hitch and weight is transfered from its front to rear axle. There is a 50kg limit on the download that the car can take. This makes loading the trailer rather tricky and I would recommend only towing a single axle trailer or caravan.
That's a common issue with a lot of newer diesels and especially those economy specials. whattowcar.com has downrated the new Passat with manual box because they all now come with gearing from the Bluemotion model.
Over on caravan talk forums there is a shift towards automatic towcars because of this issue and recent manual clutch/DMF issues. Torque convertor auto's and wet clutch DSG's are designed to slip and provide a more progressive get away. Dry clutch 7 speed DSG's have a very low first gear for slow speed manouvering so again this makes pulling away with a heavy load easier.
Modern caravans are very heavy, to get one light enough for a Fabia you would be looking at one of the very small light weight specials like the Freedom or Eriba.
Nose weight is a nightmare for the modern caravanner, the caravan club recommend nose weight to be 7% of the caravans maximum weight. Look at the maximum weight of a new 4 berth family van and they will be approaching 1500kg so 7% noseweight would be 105kg.
This actually exceeds the Alko tow hitch's maximum 100kg load and even bigger saloons only usually have a 80-90kg limit.
Lee
Edited by logiclee
Thanks for the information.
I want to tow a medium sized trailer for mowers, garden cultivator, bags of compost, plants, etc. The trailer I tried was meant for builders so it cold carry all this and more. However, with the weight, the car wasn't really happy pulling away and the trailer was difficult to balance to get the hitch download correct. So I have ruled that size of trailer out.
However, the local trailer builder (Tow-Win in Norwich) has been very helpful and suggested several things. He is willing to build a trailer to my requirements if I can provide a specification. So that is the next step.
