Radio question
Has anyone on here with an aftermarket head unit moved it down to the lower slot please.
If so what did you have to do, I tried moving mine again tonight with no luck.
Yep I have. What's the problem?
Unless I am being thick (lol) it seems to be very tight on the sides but the main problem seems to be the strut at the back is stopping the radio going in far enough.
Do I need to chop that out.
When I fitted a double din head unit in I had to chop bits out at the bottom to fit it due to it been very tight so would of thought you would have to do the same to move stereo down
Thanks, sounds like a plan, will have another look tomorrow
All sorted, it is now in the bottom slot.
