Superb 2 ETKA Request
Hi Guys
Can anyone with ETKA for the superb 2 check some gear ratios for me? Apparently ETKA is the only place they are published.
I want to compare the 2wd manual 125kw/170hp tdi with the 4wd manual 125kw/170hp. PM is fine if someone has info but doesn't want it public.
Cheers.
Anyone?
Is the Superb 2 on the ETKA that normal people have access to?
My ETKA is 2010 and doesn't seem to have anything about diff ratios on it. Being from 2010 it probably doesn't have the 125 engine either. It asks to update each time I run it but following an update never works again so I roll back the snapshot.
Perhaps you can tell me where in ETKA to look?
Thanks for helping.
Unfortunately I know nothing about ETKA so can't help with the nuts and bolts side. I'm pretty sure the 125kw CR engine was available back in 2010, but I don't know the actual engine code to confirm. I suspect it's CAGA for the 103kw engine and CAHA for the 125kw version longitudinal in audis, I'm getting CEGA, CFJA, CBBB and a lot of other codes coming up in my research.
I have since found the Skoda gear ratios on a german skoda site, so now I'm looking for the Passat ratios to compare. I don't know if it will list gear-ratios, tooth counts in the gearbox or just part numbers which need cross reference.
Edited by Kiwibacon
