changing maxidot
Hi fellow Roomsters. Having problem changing view on maxidot,have phone info on it and cannot change it to any other view.I am pressing the bottom button on the right hand stalk and also the one on end of stalk but still stays on the same view. Anybody had this problem, and how to fix. Thanks in advance. :devil:
I sometimes have issues with this (Octavia).
Assuming the display is showing the phone icons (ie signal strength, network etc, not the menu), hold the "up" button on the stick (say 5 s). When you let go, if you get the phone menu, scroll to the bottom and select back (with underside button) to go back to the icons, then repeat. If you get the mfd/audo/phone etc menu, scroll to the one you want.
It normally works the second time for me.....
hth
Steve
Edited by sdenny
Thanks for that sdenny. Worked second time also.
