sat nav voice / icon
Hi folks, on my Yeti 2.0lt urdan it is fitted with the Amunsden sat nav unit. can you change the voice and turn the arrow pointer into a car like you can on the dash top Tom Tom units ? if so hows it done ?
In answer to your query on the data used by the RNS310 Amundsen.
I have opened the file structure of the new version 4 maps and there is no way to change icons or voices.
The operating files which are loaded when the CD is inserted are all in ".dat" format and although I can open these, they are all in non-discript figures.
I will make an SD copy and check again, but I am almost certain that the files will remain in the same format.
I will post my findings later
EDIT: Although when making an SD copy there are more files to open, it looks like it is impossible to change anything without a source code convertor, and I would think that will be closely guarded by Blaupunkt and Tele Atlas, the makers of the unit and software.
Edited by Tech-Yeti
Thanks for that, Its not that i mind the voice or icon, just thought it would be fun to have scooby doo get me lost once in a while !
Do you think my April 2012 Urban will have the latest maps you write about ? how can i tell ?
BB
Start the "NAV"
Press "SETUP"
Select the info section and it will tell you which version of map you are using, V3 (Apr 2011 - Mar 2012), V4 (Apr 2012 onwards). V4 is only a couple of megs bigger and both have 7 digit postcode entry.
Edited by Tech-Yeti
What do Skoda charge for an updated map..not the usual £200 rip off I hope?
From the Blaupunkt online shop, £124 per CD set (CD1-UK, CD2- UK+Major roads Europe), from Skoda ???
Can't find site ...only blaupunkt direct uk which lists TravelpIlot disc which don't mention SKODA
Can you point me in right direction please.??
Tech-Yeti
Nav then Set up didnt show me the the v3 or v4 icon for the map in use told me i was 0038 Europe ?
Managed to turn up her voice and alter from economy to fast
