VAGCOM
evening all,
I picked up my new vrs at the weekend and i asked for the auto locking option to be turned on via VAGCOM which they did. However does anyone have a list or know what else can be done?
Have a look on the Vcds /diagnostics forum section ;)
Haven't found anything relating :/
here r just a few (via VCDS)......
Cornering Foglights
Control Module > [09] Central elec / Coding / Long coding helper / byte14 / bit 5, Check the box.
Exit
Do it
DRL dim on indicator - "Daytime Running Lights (DRL's) inactive with Turn Signals active"
Control Module > [09] Central elec / Coding / Long coding helper / byte 15 / bit 3, tick the box.
Exit
Do it
Coming/Leaving Home Lights via Foglights
Control Module > [09] Central elec / Coding / Long coding helper / byte 17/ bit 3, tick the box.
Exit
Do it
Comfort Indicator Flashes
Control Module > [09] Central elec / [10] Adaptation / Comfort Turn Signals / New Value / Up, Up.
Save
Yes
Done, Go back
Edited by JR RS
Im after the coming home/ leaving home lights, is this possible even though my car doesn't have auto lights?
Yes it can be done with vcds only if you don't have auto lights it will do it all the time (instead of just when it's dark)
Thats what i thought with its been on all time, how do i go about switching it on through vcds?
guess u didn't read my post above?!?!?!
EDIT: - Ignore this post. i didn't read ur question properly.
Edited by JR RS
Word of warning;
I had Coming Home/Leaving Home enabled using VAGCOm a few months ago. Unlock the car, main lights would come on. Enter car, insert key, turn to preheat and lights would go off. Then start the car, and after starting I would manually turn the lights back on.
Coincidence or not, in a matter of 3 weeks both my headlight bulbs went. Talked to a few people, and after explaining the "Off-On-Off-On" behaviour, they said while normally it shouldn't cause a big problem, it might have caused old bulbs to fail.
I had it disabled, and invested in Philips Xtreme Power bulbs and Philips Daytime 4 DRL Daytime Running Light set. Way better option in my view. The Xtreme Powers are bloody expensive though, and I don't want to risk them going sooner because of CH/LH coding.
Edited by Too Tall
Word of warning;
That´s why most of us have CH/LH on foglights:)
Could not be enabled on my car!
Iv seen that fog light can be done will have to see
Sorry, this as I know, but could be wrong so do please correct me, can only be done on FL models
