Bolero SD card error
Been trying to get SD card to work on the yeti but keep getting error message -see attached. I have tried two different cards and same issue. The sandisk card was purchased yesterday as thought maybe older card incompatible? any ideas why wont read? is it OEM software glitch and need garage updating? or is it the cards them selves? I have copied all mp3 files to both (only about 600MB data so far) and can access via PC card reader so able to read. how can you check if your sortware on bolero requires updating etc - would this be covered on warranty (2010 original purchased).
regards
Then card needs to be formatted as Fat32, if you are using windows then by default it will format the card as NTFS which the Bolero cannot read.
Both those cards should work fine.
Thanks Mannyo, checked and were NTFS. Reformatted and now have mp3 tunes :)
