Fabia 2001 1.4 16v running fault
Hello again,
I do have a another fault on the car listed on another topic, didnt want to confuse with this one.
The Engine warning lamp has come on again. Have had to reset it 3 times this year already. The last couple of times it has been an EGR fault which has been reset. I have cleaned out all the carbon build up from the Housing under the throttle body, but it has now come on again. I havnt had it plugged in this time just gathering its the same dam thing as it usually is (ok maybe not always a good isea to guess, but has always been the same thing).
The only thing I have noticed is the revs going up an ddown a little at idle, that about it. Maybe missing slightly.
Any ideas on things I could check?
Cheers,
Clive.
