Eezibleed
I did have an eeazibleed kit many moons ago when I had my Imp and all it seemed to do was cover everything in brake fluid! I think it was a metric/imperial incompatibility thing. I cant seem to rid my brake lines of all the air and wondered about getting another kit. I just want to test the water with other felly owners before buying one. Do they work well with fellys?
Yes, it will work fine but keep the pressure at or below 15psi.
there are better solutions for bleeding the brakes on your own.
- a manual vacuum pump - bleeds air by sucking fluid through bleed screws
OR
- a manual pressure pump - pushes in a more natural way the fluid and air through the bleed screws up into fluid reservoir (atmosphere)
OR
- a combined kit of the above two (see http://www.amazon.com/Mity-Vac-Mv8500-Elite-Auto-Test/dp/B002B4LOC6/ref=dp_cp_ob_auto_title_0)
avoid any plastic kit.
my middle name should be iHatePlasticOnCarsAndMobiles
