Malfunctioning USB Stick/MP3 Player
I've got a Sony NW-E005 USB stick/MP3 player
It has up until recently been an absoulte dream; however it has recently malfunctioned somehow.
All the rgualr functions worked and it played/searched/changed settings/charged by USB perfectly however when I connected it to my PC to charge or to transfer differnet music on to it I got this error
I've tried deleting the drivers and software and cleaning the connectors but to no avail.
I can't change any settings or format it via the PC as Windows refuses to recognise it and it doesn't even appear in "My Computer" as a USB device.
As a last resort I used it's internal menu's to do a "format" but all that did was delete the music; essentially reducing it to a very small but very effective brick.
Is there anything I can do?
Are there any super USB recovery tools out there? Although given Windows won't even recognise it I'm not sure i could actually use any of them on it!
Have you tried a different USB socket on the PC?
Have you tried connecting it to another PC?
Has anything got into the USB socket? (dirt etc) That could cause a dodgy connection.
yes no change
yes no change
possibly - i've ben using it in the garage while I was refurbing my alloy so i could be full of dust.
However i have blown it out with an air duster and nothing has changed
If you can get it apart, without damage, then electrical circuit cleaner will probably help.
I'd be guessing a small short somewhere from metalic dust.
I've had this problem before with some cheap brands of USB memory stick. I've never found a way around the issues described above and have always had to bin them.
Why Sony don't manufacture these small factor MP3 players with SD slots is beyond me.
