Secret codes
is it true that you can change the display on your climate control to show the current speed,etc...as you seem to be able to pay for this info on e-bay...anybody got any ideas on what you have to do?????? :thumbup:
try
http://www.briskoda.net/forums/article.php?a=82
ummmmmm...off for a play..cheers!!
The speed reading isn't all that accurate.
It's about 10% below the dashboard reading , and people with GPS have suggested that the correct reading is about half way between the two
It's about 10% below the dashboard reading ' date=' and people with GPS have suggested that the correct reading is about half way between the two[/quote']
I don't know if it's different on the Octy, but the GPS I use in my Fabia shows about a 5% difference from the speedo reading (32=30 and 74=70), which seems about right, judging by what Dr Zoid's just said...
If it makes any difference, the speedo readings actually far more accurate than I thought! :rolleyes:
Deleted - me being stupid and posting in the wrong forum :rolleyes:
  • 1 year later...
Mine reads the speed in Km/h:confused:
Can i change this, or am i on the wrong setting??
JD
Press Econ and Auto together to switch between metric and imperial units.
Can i change this' date=' or am i on the wrong setting??
JD[/quote']
Not with the Mk1 octavia. It only shows speed in km/h
Er - no it doesn't. Please refer to my post above...
stand corrected, although i thought that only applied to the temperature.
