Tyre size
Hello, on the face lifted Octavia and the 1.8 tsi engine, what is the standard wheel size for these cars ? Presume its something like : 205 / 55 / R16 ?
correct
205/55/16
225/45/17
225/40/18
Will also fit
Thanks.
What are the other 2 tyre sizes that you list ?
All three tyre sizes have the same rolling radius so in your speedo will show the correct speed if you go for 16", 17 " or 18" wheels
Many Octavias use all three wheel/tyre sizes
But, for the avoidance of doubt, always use 4 tyres of the same size unless one is your temporary spare.
Edited by Jeeves
Good point
So essentially, the default tyres on a face lifted Octavia are :
205/55/16
However, if you want you could also replace the the 4 default tyres with the below if you wanted :
225/45/17
225/40/18
i.e. the default alloy size of the Octavia can be fitted with all 3 of the above tyre sizes
205/55/16
225/45/17
225/40/18
Different spec levels will have different tyre size, the L & K has 17" wheels and the Vrs 18" wheels but yes the base tyre/wheel size is 205/55/16.
All 3 will fit. I have a Vrs on 18" wheels but in winter I have 16" wheels with winter tyres on, the same rolling radius
