Fitting spare wheel to Greenline II
Our new Yeti greenline is ready this week ,and I was going to swap over the spare from our old Yeti 4x4 (oct 2010 build).
On doing a bit of research on here I think the boot floor is a different shape?
Has anyone fitted a spare wheel to a Greenline?
Will I need to buy Some differently shaped boxes for under the boot floor?
There is a complete kit that contains everything available from the dealers.
I personally have a full size steel wheel & tyre and throw it in the back when going on longer journeys because I prefer to keep the lower boot floor.
The deep tool box that goes through the floor will be missing on the 2wd; you will need to get a polystyrene tool retainer that sits under the spare wheel. Everything else should be the same.
See the spare wheel guide in the tech section.
http://www.briskoda.net/forums/topic/156798-spare-wheel-assembly/
TP
O.K. everything has swapped over with the exception of the deep tool box.
The jack, etc, is now in a tool roll in the space the box would have fitted.
