Can I Use This Engine Oil?
I've got 2 litres of Castrol Magnetic 5W-30A1. It says it's meant for a Ford (my previous car) but will it be okay for my Skoda Fabia 2001 1.4MPI?
http://www.castrol.com/castrol/sectionbodycopy.do?categoryId=9024084&contentId=7073092
Castrol recommend you use Edge 5W30 - if you're going to use Magnatec they recommend 10W40.
If you already have it, see if it conforms to either:
VW 501.01
VW 502.00
VW 504.00
If it conforms to one of those you, according to the owners manual, should, in theory, be able to use it - but I obviously can't guarantee my advice :)
Best advice is that you check your owners manual and compare the Oil Specification codes (should be P156).
http://www.castrol.c...ntentId=7073092
Here we have some excellent use of grammar! You have a good command of the English language mate, something rarely seen on a publicly visited vehicular resource. :giggle:
Thanks! That's very kind of you. It's probably down to the marketing degree I've just finished added to living with language students (although you'd be surprised how bad some marketers are with English...)
I will now be exceptionally embarrassed if I've messed up the grammar on this post! :giggle:
I'm debating whether there should be a comma after finished, but, ill forget about that.
