DIY Aircon charge
My aircon doesn't pump out cold air scince ive had my car. Been thinking of buying a can of aircon aerosol. Does anyone know where the intake nosel is? Think I may have seen it, looks like a red valve near the oil sump no to sure though.
Edited by Vanders
generally run around front slam panel there will be a thing black cap on a branch off the pipe and a thick one again with a wider cap (sometimes with a dent in the cap)
you want the thick one
Waste of money ! if you have a leak it will just disapear, plus it is ileagal to allow the gas to the atmostphere.
Take it to a air-con expert as it could be a number of things, seals leaking, a hole on the pipe, and the compressor, or there might be enough
gas, but a problem with a presure switch.
So your can of might be a waste of time !
Radiotwo
As said many times on this forum, air con gas is measured by weight ( the correct weight is on a sticker on the slam panel) NOT by pressure as per refill can.
