Airfilter questions. (2006 vrs TFSI)
Hello.
A couple of questions if I may:
1. Where is the air box/air filter located in the engine bay and is it easy to get to? Could a novice replace it quickly/easily?
2. Is the air filter on the TFSI vrs engine a flat panel filter or a round filter? Searching some sites for air filters using my reg and reg year/model returns a choice of either a flat panel filter or a round filter.
Thanks in advance.
It's located in the top of the engine cover. Remove engine cover and air filter can be removed by unscrewing the housing underneath iirc. Easy enough to do once you've managed to remove the engine cover. It's a flat panel.
Thank you!
You'll find this useful: http://forums.vwvortex.com/showthread.php?2547554
Tried and failed to remove my cover earlier today, worried about pulling too hard as they're well known for cracking.
A top tip apparently is to run the engine for a short while first, which will warm up the rubber grommets it sits on.
  • 2 years later...
Thanks for the advice, and the link to Briskoda. Just managed to change the filter without breaking anything, or too many dramas.
Happy days! But why do they make it so difficult??
