Big Thanks to Mike H today
He fitted my Hids, and was slightly puzzled as they did not need to be coded,as I bought the none can-bus ones, they just worked strait out of the box, a 5 min job to fit and tuck the controllers inside the lamps.
Thanks for that Mike, also updated maps at the same time, with speed cams
Edited by skippy41
you meen canbus ones, if they were non canbus you would need to code
Will you need stick on light washers :giggle:
Will you give it a rest , do you search every thread on lights to say that, I will tell Artur( at ABC to make your Banana go in circles :kiss:
Yes :moon: :kiss::rofl:
And please call my car Ambrosia
Had a drive on a dark road tonight what a massive difference, can see the road now, will get them checked on a beam setter just for piece of mind
What's wrong with Banana?
Mike
She rumbles a bit, uneven tyre wear, Mike, she's going to ABC garage to have the 4 wheel alignment done
As recommended by Alan, AKA bluevrs2
Will post the results later
