Slow seatbelts
Hi all my front seat belts both driver and passanger dont really wind there self in does anyone else have this problem or no how to fix it
They're probaby realy grubby!
Scrub as much of the belts as possible with a stiff brush and some all purpose cleaner from a supermarket and they will work again.... worked for me!
Did mine today and it hasn't worked :( how do your remove the B pillor
So annoying how slow they go up and the passenger one is actually twisted from factory or something so think i need to remove b pillers aswell
good way that has always worked for me is pull them right the way out spray polish on it like furniture polish (i use cleaning squad) let it go all the way in play about with it for a bit maybe do it again always worked! :)
Sweet ill give it ago fingerscrossed but i need to somehow unbolt my passanger one as its twisted :S
Remove the front seat and the bolt goes into the bottom of the b pillar that holds the seat belt.
After removing the pilor how the fu*k do you get it back on?
If its the plastic your talking about it should just pop on with a firm push.
It's the middle part.
