rear speakers
This might be a silly question but went into the local dealer to see about some rear speakers
I asked how much it would cost but to be honest I dont think he knew....
Does the standard fabia 1.2 htp have rear speaker cables or will it need wiring up?
you will need to run the wires your self.
easy todo tho.
Is there a guide at all?
Im not sure I think some one else has asked befor try and do a search.
Sent from my HTC One X using Tapatalk 2
I did a search before but no luck ><
The pull park of the door comes off which then shows two screws.
There is all so a small screw at the bottem of the door, detach the window handle. The door will free to pull off. Then all of the trim along the side of the car pulls off..... It's quite simple.
Hope this helps!
