Considering coilovers for Octavia RS
As topic says, i'm considering coilovers for my RS. It could be nice going a little lower than with the current 30/30mm lowering. I think i'm going for the Vmaxx setup, but do I need a pair of adjustable 'dogbones' if i'm going to use coilovers? Don't know if you're calling them dogbones in english, but here's a picture of what I call a dogbone :giggle:http://oem-autodele.dk/images/thumbnails/250x200/FFFFFF/images/508761_1.JPG
And for those of you considering to learn danish, they're called 'stabilisatorarm' in danish :rofl:
I call those drop links. As far as I can find there are no shorter ones available for the vRS but you don't need to shorten them.
Mine's lowered on VMAXX coilovers.
It looks good but I don't like the ride very much, it's quite bouncy and harsh at low speeds (up to 60kph). At higher speeds it feels pretty good.
They have settled in a bit now after about 10,000km but I'm going to change to more expensive coilovers soon.
Im running kw v1's on stock droplinks! Ride and height are bob on! Much like standard not harsh at all but no wallow through the bends and no front end movement on acceleration and braking
Complete transformation! Think they were only 550 for v1 basics!! All the octy needs
Got Weitec Hicon GT`s here, been on about 2 years now, standard droplinks, superb ride/handling handling balance, and looks great-job done.
I've read on other threads that the Weitecs are prone to corrosion, do the Vmaxx suffer this as well?
My VMAXX still look good after 18 months on the car but we don't salt the roads here so that helps a lot.
weitecs are fine. just protect them before putting on the car and if your that bohered like me strip it down once a year and clean them up and re protect. fit ne bearings n tops and jobs a good one lol.
glad i not usin the octy ne more lol.
kwv3 ready to replace the weitecs. if i can be bothered to do it.
Probably a dumb question but how do u protect them?
you can get spray waxes.
dont spray the rubber parts or the tops /ends of the springs tho as if you do they squeek lol, then you gotta strip it down again and clean it off.
my mistake once, never again.
toolstation spray wax I used, light spray on leave to dry and it protects fairly well,
Had my Weitec's on for 3 years now and never had a single issue. Fit and forget.
I use the car every day so they've had a tough life too.
If you don't want the struts to go rusty on the surface then get the Inox V1's.
Cool, thanks for the advice guys. Oh and sorry for thread hijack :o
Very good guys, i'll go for coilovers then. I just know that some Golf mk4 requires adjustable drop links if you want to go low.
Rob i'm so happy for your comment on my subject. I obviously have some doubt in that Vmaxx suspension, 'cause it's in the cheaper range of suspensions. So i'll definately think about it when it comes to the Vmaxx. But hey, your car looks great!
When installing mine i just lathered the thread in copper grease and ran the adjuster over it to grease the threads! If they get stuck and i ever feel the pointless task of readjusting them (which i wont) i have some 3ft stillsons in the shed :o
Rob, VMAXX in pix, how much is the estate dropped by? initially and after settling?
Edited by G-slave
I think about 25mm lower than the standard vRS height. I haven't measured exactly.
Ordered some Weitec GT's :D
Will be fitted next Friday...
Good Choice. I have them and are up and over speed bumps every day
I'm going to protect with duck oil
Thanks to the advice of these lovely people! Duck oil? Never heard of using that before...
keep us posted
Just very waterproof so protects
Sounds like the good stuff! What duck oil product should I look out for then? Was planning to use Fk1000p...
This is because MK 4(except R32) has completely different ARB and drop link set up. Golf ARB links are fitted to the wishbone, the VRS like R32, S3, TT and LCR are fitted from ARB to suspension strut and are longer but do not go anywhere near drive shaft like the Golf. The Golf needs shorter links on heavy lowering beacuse the driveshaft comes in contact with ARB if std length links are used.
There an no shorter links for VRS as none are needed.
Weitecs are a good choice for comfort, but do not go too low on them as you will suffer with harshness.
Mine also started to slightly corode and i covered in light grease to protect them. But I am fussy.. :giggle:
Upgraded to KW to get a fully shock/spring adjustment in the end, but not needed for most folks.
You will be impressed buddy with them.
Where did you end up getting them/how much? :)
DPM performance. £468 delivered. I hope they get to me on time...
