Wheel bolts
what size wheel bolts will I need with 15mm spacers and the best place 2 get them
Are they bolt through spacers?
Yes m8 H&R ones
27mm is stadard so plus 15mm would be 42mm youll be more than ok with 40mm length ones :)
What size spacers do you guys use on the front and rear of the VRS? Mines on coilovers and really does need spacers but I don't want it to scrape!
Any recommendations? Someone mentioned hub centric to me an that they need to have the locating ring
Also you need to get the correct "shoulder" for your alloys......bolts are either "radius" or "taper" shoulder..........eg is the bit between the thread and the head of the bolt curved so it looks like a hemisphere (radius)....or is it a straight line so it looks like a cone (taper).....
