Windows Slower than others?
With the weather like this i like to use the global unlock off the fob but the last few times i have noticed that the rear drivers window is sometimes slower to come down than the rest but it goes back up quicker than the rest!
Is this a sign of impending failure? They have always gone up and down at the same rate.
Try some silicon spray down the window guides
Had same issue when weather hot in April. I know, I know ages ago. But this solution worked for me.... And it stopped the squeaking.
Edited by adamal
The silicone spray? How did you apply it? Just flex the outside rubber out and squirt it into the door?
Don't fancy dismantling my door to get to the window guides!
No just in place, dropped window and sprayed into guides and then lifted them
No just in place, dropped window and sprayed into guides and then lifted them, worked fine for me.
Thanks.
