ECU changeover
Hi,
I have a Octavia 1.8t 2003mod AUM engine automatic transm. with ECU 06A906032HL.
Is it possible for me to use a 06906032HJ ?
wont it be programmed to the cluster/ immobilizer ?
It should be ok it will have to be coded tho.
Thanks for your answers.
Yes I'm sure it is coded, I looked around at NefMoto forum and I managed to pull my SKC from my old ECU,
so then I should be abel to also pull the SKC from my "new-used" ECU and code it in with VCDS (vag-com).
Or write the contents (bin-file) of my old 95040 IC onto my "new used" 95040 IC ("immo-ic")
I'm just wondering what the main difference is between the ECU's, that all have the same part no, exepct from the last two letters.
Do you thing I can use any ECU that have a part no like: 06A906032XX ?
Do they all have the same HW inside?
