Oxygen lambada sensor error ?
Dear All
I just scanned my car with VCDS and found that error
Please can someone explaine to me what is that and how to solve it ?
best regards
MAK
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Control Module Part Number: 06A 906 033 FE
Component and/or Version: SIMOS71 1.6l 2VG 8724
Software Coding: 0000075
Work Shop Code: WSC 73430 790 00000
VCID: 67D7CA385676CB6
1 Fault Found:
18669 - Oxygen (Lambda) Sensor B1 S1
P2237 - 009 - Pump Current Open Circuit - Intermittent
Freeze Frame:
RPM: 3264 /min
Mass Air / Rev.: 414.2 mg/str
Voltage: 1.880 V
Bin. Bits: 00000100
RPM: 1920 /min
Mass Air / Rev.: 365.2 mg/str
Voltage: 2.020 V
Bin. Bits: 00000100
Readiness: 0000 0000
Looks like a faulty lambda probe at a guess, normally when getting pump current issues and heater issues it's the probe itself, they do give up after a time.
many thanks for your fast replay
you mean this error related to lambada sensor or the fuel pump?
if it is lambada sensor , which one as i hearded they r 3 or 4 (i am not sure )
Bank 1 sensor 1 is in the exhaust in front of the catalytic converter
i got what you mean now,
so this one need to be replaced , or i clean first and check.
Its probably worth just replacing it.
