Disadvantages of an EGR delete?
I blanked off my EGR pipe a while ago now as it seemed like a really good thing to do and i know is popular with the pd engines
Now im getting told off a mechnacic that its actually a bad thing to do and is probs why im having problems now?
Any ideas diesel heads?
What problems are you having?
Which engine you got?
ASZ or BLT?
Phil
Disadvantages are...
Increased NOx emissions.
On cars with an EGR cooler, the engine takes slightly longer to warm up.
Can be noisier at idle.
Higher EGTs at idling/cruising.
Increased rate of combustion and thus local peak temperatures.
Loosing power at top end, excessive oil around turbo
Aparently its a really bad thing
Where does all the soot go once youve blanked EGR pipe off?
Out the exhaust I would have thought :)
I've not done this mod myself thought
At the top end (WOT), the EGR is essentially off.
When the EGR is off/blanked any soot continues down the exhaust.
An EGR on a diesel actually increases soot production. It can also increase oil acidity which is detrimental to engine (and specifically turbo bearing) longevity.
Egr recirculates exhaust gas back into the inlet manifold so removing it can only be a good thing
What a nonesense. Having the exact same gases the engine produces anyway sent out the back instead of back into the engine. OIL ACIDITY? really? clean air in dirty air out, how the hell can that be bad?? Oil around turbo - oil is on other side and weeps through a little anyway.
NOW nox gases......... YES worse, so.... dont get your mot done in japan, stay here
Edited by Lofty79
lets be honest why the hell would a manufacturer produce a part of the engine that would deliberately shorten its life...
and if its shortening the life well i must have the best engine in the world beacuse i have had an EGR fully functioning alongside a perfectly well performing engine for over 130,000 miles..
...OIL ACIDITY? really?...
I think you've read it the wrong way around. Adding EGR (making the engine eat its own poo) increases oil acidity.
Ah yes, was on ma wee soap box there eh? I shall climb down
...why the hell would a manufacturer produce a part of the engine that would deliberately shorten its life...
Adding an EGR is the cheapest way to reduce NOx emissions (legal requirement) and engine life is only shortened by about 1%.
Because of the emissions race mate. Most manufa turers choose to have a car not running to potential to score points. 130k is not alot of miles
hmmm yeah fair enough i guess...good old 'green' motoring..lol
I'll get an extra 200 miles great
seriously though, cars can run well with them, but i prefer the clean air and the fact that if it were to be faulty its an extra bit to buy
You only planning getting 20,000 miles out of a PD engine then?????? :happy:
I'm interested to see where the 1% figure comes from?
Haha no im near 200k just now, want another 200k. My calculations were askew. Shes not a pd, good ol direct from pump
been EGR'less for a long time - probably 5 to 6 years. Funnily enough, never had a gummed up turbo vanes problem. ;) Also I have a lovely clean inlet manifold tract. No cack at all which means reliable airflow 100% of the time. Look at my shocking build up of cack after 20,000+ miles without an EGR! :(
It came from research done by Mercedes approximately 20 years ago. It gave 1% as a worst case figure (which was lower than predicted). It also stated that expected improvements in oil chemistry would lead to future reductions.
This is all it takes to put me off having an EGR. Yuck! That kind of blockage would lead to more than a 1% reduction in lifespan/performance in my opinion.
here here, mine was like that, all it takes is a choke up pulling a hard lump into the engine. or stop it up completely. Never any sticky vanes????? I sense a heavy right foot
I don't understand how this happens? I'm running an egr and my intake tract looks like your other picture above, 92000 miles later
