Felicia mk2 8v gti engine conversion
Help
I have engine box loom, also all parts for rear disc conversion. But really after help with engine swap out
Read TeflonTom's threads on the 2.0 and 1.8T conversions then. Hope your good at fabrication.
Cheers, il use expanding foam if I got to
Can I mod golf 2 subframe into felicia
they bolt in diffrent you need to use felicia one and use felicia gear box and get a engine mount made you will need some parts off a 1.6 like flywheel and adaptor plate from vw engines to skoda boxes electrices are easy to sort
Read TeflonTom's threads on the 1.4 16v and 1.8T conversions then. Hope your good at fabrication
looking at doing this to mine but have a obd1 vr6 engine but can't decide
Edited by uma1998
I don't understand why you want other engine when you are absolutelly out of all about engines and mechanincs... Keep the original engine and your life will be easier. ;)
just stick the 1.6 aee engine in bolt in and away you go
:) I have 1.8T in my felicia, so i think that i know what i mean. ;)
1.8t are the best going to do this to mine in future
