Engine management light on
The code which is coming up is p1556 any one now what the problem could be also now and again car goes in limp mode
17964/P1556 - Charge Pressure Control: Negative Deviation
Possible Symptoms
  • Reduced power output
  • Limp mode
Possible Causes
  • Boost Pressure too Low
  • Hoses/Pipes incorrect connected, disconnected or leaking
  • Charger Pressure Control defective
  • VNT (variable nozzle turbo): nozzles stuck
  • Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
  • Check Hoses/Pipes to/between Components
  • Check Solenoid Valve for Boost Pressure Control (N75)
  • Check / Clean / Replace Charge Pressure Control
  • Check / Clean mechanism for variable nozzles
Cheers for that mate its had a other n75 valve on but never had codes clear it wouldn't still do it would it
Sorry forgot to mention ther turbo laggy to about 2500rpm to 3000rpm
It sounds like either sticky turbo veins, boost leak, faulty vacuum connection/controller.
Check all the vacuum connections, all boost pipes and try giving the turbo actuator a push (it will be pretty stiff anyway but should have some movement to it).
Phil
  • 6 months later...
I'm having the same problem currently :( glad of this thread... Will give it a try :)
J.E
