maxi dot retro fit
Can i fit the following maxidot to my 2006 2.0 140pd octavia sport
1Z0 920 903N
I'm not sure if this is of a CR or a pd engine not sure if it matters or not.
any help would be great,
thanks
Jef
The clue is in the pd140 you just told us
My car is a 140pd. But I do not know what car the part number(dash clocks) come from?
Does it matter if these are from a cr car. Will they work in mine
Yes it does matter, the CR and PD require different clusters.
But any PD pre facelift cluster will work, it does not necessarily have to be a vRS one. i had a vRS maxidot fitted to my PD140 Octavia Elegance and it worked perfectly.
can anyone tell me if the above part number will work
That particular part number is coming up against a much later model year, so could be for a facelift model which is not compatible in any way with a 2006 car.
From what I can make out its for a 2010 MY with engine code CEGA.
You cannot interchange between FL and Pre facelift, the connectors are very different, wrong immobiliser chip etc.
thanks for clearing this up so looks like i will have to go to skodateile for mine, they are down until start of september, quite disappointed about this
Only a few more days.
  • 9 months later...
What's the name of the man from Skodateile ? Ales Prazak ?
1st July according to their website - I'm waiting to look some stuff up!
If you want it fitted, the dealer may do it for a large fee, but Eddie_NL can do most cluster swaps. Would be worth PM'ing him to see what else you need to make it as simple as possible.
What's a maxidot?
Sent from my Galaxy Nexus using Tapatalk 2
  • 10 months later...
Can you not just fit the maxidot screen over to your existing cluster??
No, the internal circuits and cluster software are very different.
