lowering car windows
Is it possible to use key to lower car windows on superb?
Currently I cant try, but last time I tried I heard from people, yes but I didnt suscced.
My mechanic told me that I need to use softwer to learn my car that possibulity?
Is this tru?
Sorry for my english
im guessing you will need the vag-com software.
Ross-Tech do it.
OK, do you know will it depend if car is classic, comfort or elegance?
Maybe they didnt built in that option in classic or comfort?
As far as i'm aware, if it's remote central locking, then you simply have to hold the lock/unlock button on the remote to close/open all the windows - works on mine at least!! :)
If it's not 'remote' central locking, then holding the key in the lock/unlock position in the door should work in the same way - again, at least it did on my old car and my sisters (SEAT Toledo / VW Bora).
Yes - either hold down the alarm button, or turn then hold the key in the door to open/shut the windows.
And the sunroof :thumbup:
Edited by sidewaze samm
:( Unfortunetly on my car this isnt possible.
I dont know reason, but I tried both ways and none of them working.
Apparently on Classic this option hasnt been built in. :(
Its not major, but it is preety big minus.
I think it is possible but it depends on which model of CCM you have. i made a quick how-to a while back. Check the link below.
Auto-Windows
Hmmm sounds interesting and easy to do.
Tnx for your "manuel for idiots":)...but I have few questions for you.(I hope you can answer) :think:
Nowadays in my country its very hard to find cable that have serial, is there other way? Even I find that cable, I cant find notebook :( :sweat:
Can I use OBDII usb cable or bluetooth? :wonder:
Oh yes, I allmost forgot, do you know is there another "cool" option(mod) that it can be activated, because I heard from people that some futures are locked because it is classic/comfort and not elegance model?
I hope you understand me, my english is relly poor:( :blush:
Ok I have find out some things, and I will wrote here, to see other people if they won to do it.
All Superbs have this option built in, but for some models is softwere locked.
To be able to use that, you need serial cable and allclownsareevil's manuel.
It cant be done with usb ObdII cable, well it can but for cars which are build from 2005.
Unfortunelly I cant find that serial cable in my country because it is rare and now relly old tehnology.
But, if it is for consolation I can use this function when I set my key in door lock/unlock position.
It isnt big thing but...it is something.
All in all I will do some more investigation and try to find out solution and if find I will wrote here.
If anyone hear something or find out I would be gratefull to share with us.
EDIT:I forgot, it cant be used serial-usb adapter.
Edited by MilanM
You need to stop apologising for this. Your english is great compared to what most of our Serbian would be like!
Gaz
Tnx Gaz :blush:
Latest news:
Apparently it can be done with regural usb OBDII cable.
I will post link and if it is problem, than you delete it.
http://uk-mkvs.net/forums/t/472146.aspx?PageIndex=1
I will try next week and I will report if it works.
Tnx for your "manuel for idiots" :)...but I have few questions for you.(I hope you can answer) :think:
Sorry I didn't see your post until now. To answer your questions, I only activated my auto-windows with this method. I didn't try another one, but I'm sure it is possible.
Gaz
Agreed. Your english is fine.
Gaz
It was exactly my thought :D. Stop apologizing, we are already used to it.
