Whos Lower?
Anyone Lower then this????
And a excuse to put your best photos up!!!
I was but couldn't cope with it. Tyres rubbed on plastic inner wing just rolling along, plus I had 2 degrees of camber on one side and 1 on the other. And my rear wheel toe in was mental (fixed beam) so put it up to about a 40mm drop of standard, handling improved cos the bounce on some corners pushed me wide
theres a guy with and sdi on air ride, he'll probably be the lowest you'll find.
Or mattvrestate, he's on air and notched...
And my **** is 9" long, yours?
Not mine, but a picture taken at the Shark Performance Open Day on 27th August 2012
dont believe you but dont want proof
Whoever this guy is, he must be pretty close if not lower.
And this one at Edition 38 2011
This is a flymo (other grass cutting devices are available)
Edited by Lofty79
I was quite low..... no scrubbing at all
Currently around the same hight as OP, all be it on 17`s. Had it about the same hight as the blue one, also had D90`s. Looks good but after a few weeks found myself thinking why have I spent the best part of £3000 making the car quicker only to drive round really slow everywhere. Raised it up a little, more fun and still looks good. Without sounding old, what fun is it smashing your exhaust off every bump? Gets boring after a bit (imo of course)
This is on air i believe!
it is. . its also metallic mulberry purple now too,with purple compomotive split rims. . haha.
nothing was mentioned in the first post it had to be static?. . :-P
mine. . .(i know grass is cheating) but its as low as it'll go without causing major problems.
