Hannspree Hannspadd 16GB 10.1" Tablet Capacitive Screen - SOLD
Hannspree Hannspadd 16GB 10.1" Tablet Capacitive Screen - £110 Delivered
Specs
Inch 10.1'' Wide
Platform Operating System: Android2.2
Processor: ARM Cortex A9 (Dual Core)
Chipsetn: nVidia Tegra II T20 1Ghz
Memory: DDRII 667Mhz, 512MB
Storage 1. SD card memory has 13.09GB
2. DATA memory has 2GB , (need deduction System Image map size) UI to show has 1.7 GB .
Card reader 1 × Micro SD/SDHC, push-push type
Video Graphic Integrated on Board, 3D acceleration and GPU flash 10 acceleration
Support Image Format BMP/GIF/JPG/PNG
Support Audio Format MPEG 1 Layer 1/2, Audio MP3/WMA voice
Support Video Format WMV/MOV/MPEG 1 Video/ MPEG 4 Video/H.264 1080P
Resolution 1024 × 600
Response Time 16 ms (Typ.)
Support Color 262K colors ( RGB 6-bit )
Video Interface 1 Channel LVDS
Video output Digital mini HDMI ((TMDS interface)
Compatibility HDMI up to1080p (1.3a)
Principle Capacitive Touch Panel
Sensor Refresh RateSingle Finger @120 Hz / Dual Fingers @ 80 Hz
Capacitive Multi Touch Module Interface IIC bus
Touch Module Power Consumption Operating: < 0.041W. Suspend: < 4 mW. Light Transmission ? 86% , ISO 13468-1 Light Reflection < 10% , at 550 nm Communication WLAN(802.11 b/g/n), Bluetooth 2.1
Interaction Light Sensor provided, G Sensor supported 3D, 3 Axis Accelerometer
Interface Adaptor × 1 (DC Jack 12V/2A, Variable of Power Plug with wire 1.5m), Headphones × 1, Microphone × 1 (Built-in ), Mini USB × 1, HDMI Output(1.3a) × 1
Speaker Max. Volt setting, Speaker Output in 1.2W +/-10% X 1, 1Watts output, THD<= 8 %
Earphone Max. Volt Setting, Earphone Output > min.@75mV ~ max.@150mV, Load@ 32 ohms, S/N: <= -60db LED Indicator Power On: Green
Battery: Charging is Red, Full Charged is Green.
Wire: Wire on is Green
Power Battery: Li-Polymer 3650mA/7.4V
Consumption (on / standby / off): On: <2.7W, Standby: <0.176W, Off: <0.035W; (System default setting wiithout adapter and 3G/WebCom off)
AC Power Range: Input AC 100-240, 50-60Hz 1.0A; Output DC12V/2A
Temperature 0 to 35 degree
Humidity 10 ~ 85%
Dimension (W*D*H) 260 × 170 × 13.9 mm
Packing Dimension (W*D*H) 307 × 210 × 65 mm
Net weight 745 gs Gross weight 1.3 kgw
Function Control Keys Volume +/- and Power are Tact SW, Touch keys have HOME, BACK, MENU.
Accessories Mini USB (male) to PC USB (female) cable, Quick Start Guide (English /
The device has been rooted so you can install from a range of Roms - i will preload with Android Gingerbread
You can put the latest Jellybean Rom on it
Included is a 16gb memory card bring total memory up to 32gb
Comes with powercable, USB connect cable, sleeve (bit big but fine), Stand and screen protectors
Very good for watching movies - can manage about 6 hours to a charge on movies
I will post up some pictures when i get home
More info - http://www.hannspree...ttrs=&viewAll=0
£110 delivered
Pm or [email protected] or 07717854666
Thanks for looking
Tom
Photos
Tom
£100 delivered
How old is this mate? Also it does definitely have bluetooth? Cheers olly
Its def got bluetooth . Its about 7 months old
Tom
SOLD
