DSG problem on Octavia II
I have a 2year old octavia 1.6 TDi DSG Difficult on a slope especially in reverse.. Also in first sometimes After a few visits to dealer they have put in a new clutch pack today under warranty. Now seems ok
Anybody had this done and long term result, I wonder
rose skoda
  • Replies 81
  • Views 15.6k
  • Skoda uk will more than likely know about it. Vw uk certainly know about this one and don't give a toss (click on pistonheads link in post 10). http://www.briskoda.net/forums/topic/259414-will-i-buy
Hello. Is the clutch pack essentially the same as a mechatronic unit ?
Or is it totally different ?
The mechatronic unit is basically the gears and associated electronics.
The clutch pack is seperate I believe.
Phil
The clutch pack is separate from the mechatronic unit.
The mechatronic unit is basically a combination of electronic control module and hydraulic actuators that actually controls the operation of the gearbox.
So is the clutch pack physically installed in the gear box area also ?
In a DSG the clutch pack is inside the gearbox. The gearbox needs to come out to replace the clutch pack, whereas the mechatronics unit can be replaced relatively easily, with the gearbox still in the car.
You don't hear of clutch packs failing on the 6 speed wet clutch gearbox very much....seems to be limited to the 7 speed dry clutch DSG.
Thanks Booke
