Sai blanking plate
Where is the cheapest place to get hold of the blanking plate? seen forge do 1 at £21.00
cheers
I made one from 5mm aluminum plate and sealed it using good quality silicone sealant
CNtuning will do one for you mate. PM Clive at CNtuning.
Sai blanking plate? Am I correct in assuming that this makes the sai system redundant, without actually removing the system ? Is there anything else I would need to do, like take out fuse at least I would have thought. And finally, I take it no more boost leaks from this system at least as a result?
Now available from cntuning please pm me if you want one
can you tell us more about them - esp any side issues with engine maps because of it
It's used simply to block Sai hose when removing the Sai system wich is prone to failure and not needed really !! Cleans bay up when done @ the same time as the simplification of the vac hoses
Hi, I know what they are for, just wondering the technical details of what else needs done
I know several systems (N112?) can be removed but can this be done without flagging a CEL?
you can resistor the sai or you can have it mapped out with a shark remap
pm me if you need any more info
Hey, I am thinking of fitting a blanking plate to my EGR, (really I want to remove it if it does not do anything good apart from emissions). How would you resistor the egr to stop the light coming on? Or could I just blank and wait for an engine map? Will anything bad happen from blanking?
You can just blank and it will only cause engine light every now and again or you can map it out your choice really.
