Best power connections
Hi guy, ive aeen it on here somewhere but im being crap im sure ( again )
For my gauges....
Wheres the best place for :
IGN
PERMINANT LIVE
and ILLUMINATION
Is theres somewhere on the fuse thingy by the pedals ?
Also do i fuse each
Im thinking put all 3 gauges into a single bigger wire , then i only have 1 of each connection to find
Any help advice and defo pics would be most appreciated :)
Under the steering column is a plate with all you need. Just need to undo the nuts at the bottom and put a ring connector fitting. There's 3 altogether but you're not ment to use one, dunno which one though
Sent from my Galaxy S2 not a Crapple!
Why not use connections behind radio, you have all three there and it will already be fused aswell
Does it blow up if u use the wrong one :(
I did think stereo but would 3 extra live ign and illum be abit much on the loom ?
I ran my three gauges from the stereo loom, so smoke.... err i mean problems so far ;)
Its only led lights so cant see they need much power ????
LEDs draw so little power you would be fine.
