Plasti-Dipped my Grille and badges
I finally got around to plasti-dipping my grille and badges at the weekend after buying a can a few months back!
It was really quite easy apart from when the can decided to spit a few big globs of the stuff out now and again but most of the time it flattened out but I did end up with one slight bump but its really small. I prepped the areas beforehand with some tardis. not sure if thats the best thing to remove wax but time will tell.
First off I covered the car with a blanket then taped around the grille and gave it a couple of coats letting it dry in-between.
I put some masking tape on the badge to make it easy to remove.
As it got thicker. Probably about 6 coats here.
After it all dried I started peeling...
and a bit more... you can see the small fault here where a glob of the spray popped out.
eventually I got it all off. the part that had the dip removed is really rough so Il go over it with some car lack to clean it off. it was getting dark here and i only removed the badge dip the next day but im really chuffed with it at the moment.
not sure on the longevity of it as it was really easy to remove from the badge so it may chip easily?
I also did the badges
Hope you like although its probably marmite to some. apologies for the carp pics but it was getting dark at the end
Might do the mirrors next but will probably need another can
Looks great! I ordered my white blackline with grill and mirror caps painted by the dealer, so it's nice to see the grill black.
Would it not have been easier and given a better job with the grill removed from the car, its actually dead easy to remove.
The hole point of plastidip is that it can be easily removed. So really you don't need to mask anything off. I have done the whole car and only masked the front window and rear window due to wiper blades.
nah, by the time i found my socket set then cleared a space to hang it to spray it that would have been longer than the five mins it took to put the cover under the bonnet and mask the small area around the grille. Not sure it would have been a better finish either as the glob that popped out of the spray can appeared when it was horizontal. If youve got everything to hand then it might be quicker but my garage is full of house stuff :(
You can user thinners to rub down the area that has got the blotch on it and re do it.
Quite like the rear octavia badge. Not sure on black or coded grilles - although suspect they look better in the flesh than the pictures I've seen (otherwise try wouldn't be so popular!)
The rear badges look cool. How durable is the paint on the chrome though? I imagine it would come off quite easily if you were to catch it whilst cleaning for example?
looks good - i've got a can in the garage but never seem to get around to doing anything with it..
Looks good Stu - I like it, nice job.
Like.
I did mine in the summer, still looks fine apart from where I didn't leave it to dry for long enough and a bit of water got under the edge and it lifted.
Veri nice.
Where did you get the plasti-dip from
Ive currently got a matt black grill fitted, but Im going back to colour coded, I just think its too much on the front of the Octavia.
Colour coding grill surround only works on dark colours IMO. Black grill surround on white looks great, that's why I had mine wrapped.
thanks all. will try and get some pics up of it in the daylight with the badge showing.
I got my can off ebay alb erg
Ahhhh it was someone off here, had to be really, I saw you in Northop this morning (Bangor 60 plate?) I've seen you around a few times, noticed the grille today, tidy motor matey :thumbup:
Can't mistake you for plod now from a distance though..... hehe
Pete
Not a fan of the non-OEM coloured grill myself but the black badges on the white look really good.
Pete
Yes that would have been me pete :)
The CX plate and colour has been a bit of a curse around here. The coppers either wave at me or look confused and the local chavs in Shotton are even more confused and dont know which way to run! Doesnt help when the works uniform is a dark polo shirt!
will give you a wave if I see you!
I can imagine that plate can be fun on the A55 though ;)
I was in my works van today but likewise I'll give you a wave if we cross Octys :D
Yup, its quite fun on the a55 watching audi's and bmw's slamming on as they approach from behind :D
that must have been you at the cross road lights then in the tall van? I think I have seen a black sport knocking around as they are quite rare so must have been you :)
Yeah that was me in the Sprinter, turned at the lights as you were approaching then you followed me through the 30.
Hadn't realised quite how rare the Sport model is, they're like hens teeth, and some of the specific parts are too!!
See you on the road :)
Like this a lot! Badge looks good too.
I'm going to do the same but vinyl wrapped I think. Not to copy :peek:
  • 2 years later...
my grill peeled off  after a few stone chips and I had to remove the plastydeep
