Black Smoke remap
Had ago remapping my fabia vrs this morning. Went to black smoke download the correct map for my ecu. Made a copy of the original and saved it. Upload new map. Went for a drive.
What a difference it makes. I bought the 165bhp map and its brilliant.
Just been on the website.
Pretty cheap prices.
Can you use an ordinary vag-com cable?
Phil
Any smoke on Full acceleration?
Any noticeable difference in mpg?
and is it smooth or is it a spiked delivery?
I dont know about that cable as i dont have a vag-com yet.
should be here tomorrow thou. i used kwp2000 plus i got off ebay couple of years ago.
No smoke what so ever, not to sure about mpg yet only went up the road.
its smooth all the way. Im very happy with it.
Just had a look on there website looks good!!
Are these remaps easy to do? What equipment is required to do it other than the remap files?
Cheers :)
Carl
Cheers :)
Carl
They are good. It took me 10mins to remap.
I used kwp2000 plus. Cost me about £10 couple of years ago. downloaded the software for that.
I read my ecu and its didnt work. So i removed fuses 11 and 15(i read this somewhere) And it worked read it, saved a copy of the file.
Made sure i got the right remap from black smoke.
Paid for it and got an email with a download.
uploaded it to the ecu, put fuses back and started car. job done
For extra security I would get a mpps cable as u have back up
But black smoke are awsome and he has awsome customer support
I can echo that. Andrew is very helpful too if you need any support off him. Knowledgable guy .
I too have the 165 bhp map and the economy is excellent. Get on the motorway and bung it in 6th and it achieves about 59 mpg around 70-75
I've been swithering about using this map for a few weeks. Does anyone know the torque figure for it ?
Cant be exact without dyno run, people I have spoke to quoted just under 300pound.
Can only say how it drives and it does have plenty of torque. I have tried a different map on mine that was a higher bhp and have gone back to the blacksmoke map because it produced better torque.
Email the guy at blacksmoke i think you can request certain things for same price.
Edit: all sorted now...
But anyways, I'm getting a blacksmoke remap and what would you recommend? I have a standard vrs and I'm torn between a safe 130 to 165 map, OR jump up to a 180 map...
I'm obviously swaying more towards the 165 but I'm not sure lol. Any advice?
Edited by Laidback Luke Jones
Id stick to 165, 180 will push alot of components, at that power i think you will be looking at new clutch and alot of boost leaks, thats depending on how old your turbo is too.
He does not do a 180 map for our cars
I'm tempted by the 165 bhp map to, seems like it could be a safer bet than the harsher awesome map.
What logs would you recommend to be carried out to ensure everything is in working order before buying a map?
log 3, 8 and 11 will be ok, channel 11 being the important one after the map. No point in logging channel 8 after the remap as the black smoke file has decalibrated injector maps :think:, what I would class as dirty tuning, but it works.
Edited by bondi
Ok thanks I'll do that this week.
These maps are really tempting at £45 :)
Can anyone that's got this map be kind enough to post logs so we can see what theyre like?
I will try and getting some logs done 2nite and post them. As long as my vag com lead has arrived.
I drove about 200 miles at the weekend. I'm getting about 50mpg. So I'm very happy with the map.
Tread carefully bondi is right.
Ive had both the 180 and 165 on my mk1 fab vrs and i much prefer the 165 . The 180 is a bit spikey and tbh the 165 feels better all the way through the power range
What does decalibrated injector maps mean?
Phil
On the ecu are a number of duration maps. These maps are calibration maps. They tell how long to keep the injectors open per crank degrees to meet a requested IQ (injection quantity)
So if you request 40mg the injectors have to stay open for x amount of degrees.
Now these maps in a stock ecu only go upto 60mg (pd160 goes to 65). Some mappers alter these calibrations so they stay open for longer. Result when the ecu requests 40mg you actually get more depending on how much it's increased. This also has an effect other maps are they work of IQ. First that springs to mind is the start if injection maps (timing)
Changes like this you could call a fancy tuning box.
